  • 14 Vote(s) - 3.36 Average
ZM3E underground loop problem
Afternoon..
 We have had a strange problem, if a car is going towards the gate and we press to open, when the car gets to the underground loop (auto open) the gate shuts and will not open till the car reverse off the loop.. to get out we need to use the loop...how can I adjust this  ?
Thank you..
Mark.
Thank you for your enquiry,
Could you verify where the loop is wired into on your gate control panel, it sounds like it may be wired into 2 and 7 but in this case I would try terminals 2 and 3 which is an open only command.
(12-01-2024, 10:07 AM)benbrooks Wrote: Hi,
Hi Ben,
 On looking at the board i see all wires going into 2 and 7. i will find the right loop wire and try number 3..
Thanks for your help
Mark.
Many thanks, that worked..
(18-03-2024, 04:37 PM)GhostUK Wrote: Many thanks, that worked..
Thank you for letting me know, should any further issues arise do not hesitate to contact us.
  Ground loop Came 009SMA arc497 0 3,618 14-05-2023, 12:02 PM
Last Post: arc497
  My Came ZM3E gates won’t open golfnut75 1 10,594 12-08-2022, 08:40 AM
  CAME ZM3E Mike2006 0 13,412 28-09-2020, 07:48 PM
Last Post: Mike2006
  Came ZM3E and Frog Motors both opening on M1 not seperately giuseppem 1 18,495 11-04-2018, 07:25 AM
  ZBK Master/Slave problem Steve Jefferson 1 30,528 09-11-2014, 06:43 PM
Last Post: Steve Jefferson
  Radio Problem Distance to Antennae whelan100 1 25,103 02-01-2014, 04:11 PM
