  • 19 Vote(s) - 3.16 Average
Disable Open hold On NICE NC824
Is there a way to disable the Open hold feature on the NICE control unit ? the issue I have at one of our client sites is the gate is opened remotely via a Paxton entry system/ fob entry, nobody waits for the gates to fully open but as they pass through they trigger the induction loop in the ground on the inside ( for auto opening when leaving). This sends a second open signal which of course then holds the gates open.
It also has the same effect if someone follows close behind and also taps their fob on the external reader.
While I can see the value in the hold open feature it just doesn't work for this site.
(01-09-2023, 07:50 PM)paul@blxnetworks.co.uk Wrote: Is there a way to disable the Open hold feature on the NICE control unit ? the issue I have at one of our client sites is the gate is opened remotely via a Paxton entry system/ fob entry, nobody waits for the gates to fully open but as they pass through they trigger the induction loop in the ground on the inside ( for auto opening when leaving). This sends a second open signal which of course then holds the gates open.
Thank you for the enquiry.
Firstly which Nice control unit is it that you have? from the symptoms of the fault you have explained, You will need to enable apartment block mode on your control panel which will then make the panel ignore the second command once I know which control panel that you have in situ I can find this part of the manual and guide you where to find it.
However usually the gates will only hold open if there is a relay stuck in the closed position which is wired into open, I would see if there is potentially a sticky relay that could be causing this fault either from the induction loop of the Paxton entry system. Typically the only thing that would stop the gate from automatically closing if this feature is enabled is a safety feature such as photocells on safety edges; if you can open and close the gates now by a command then I would not say that this is the issue.
I hope the above information helps.
Hi Ben,
The control unit is a MCA1 ITEM: MCA1R10 is the information on the label on the front.
The issue is the hold open, it can be triggered by a second "open" request from the Paxton reading a card, or by a vehicle driving inwards and over the induction loop following the first open request, i have witnessed the second "open" command and the gates do remain in the open position until a further "open" request at which point they fully open then close after the timeout.
I also have another site with a MC800 control unit, would the oview programmer work for both units ?
(07-09-2023, 03:16 PM)paul@blxnetworks.co.uk Wrote: Hi Ben,
It is possible that the gate is receiving a second command then, which will result in the gates holding open.
To fix this condominium mode / apartment block would need to be activated on your step-by-step function. Instructions on how to do this can be found on page 8 of the PDF document.
https://manuals.easygates.co.uk/PDF/nice/D00011568.pdf
Regarding if the oview will work on both MC824H and the M800, yes it will as both panels have a IBT4N connection which is needed when plugging the Oview in.
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 61,883 09-01-2026, 10:03 AM
  How to disable Came DIR10 photocells after traffic accident Howardy 3 3,629 09-07-2025, 11:36 AM
  Gates not staying open JimM169 1 2,785 21-05-2025, 02:55 PM
  Nice Swing Gate Opener nicenotnice 0 4,669 18-03-2025, 06:40 AM
  Nice wingo 5400 and MC800 engrbhadz 0 2,322 18-03-2025, 05:53 AM
Last Post: engrbhadz
  Program a 3rd party remote to Nice Robus N600 P100D 4 9,340 13-05-2024, 03:36 PM
  Nice MC824H gate stuck open Markp80 1 5,975 13-05-2024, 02:32 PM
  Rigel 5 , gates won't open Nameloc 4 10,270 04-05-2024, 12:41 PM
Last Post: Alee
  Came ZA3 gates stuck open Ivorwindybottom 0 3,094 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
