  • 44 Vote(s) - 2.86 Average
#11
(10-10-2022, 09:58 AM)j1000 Wrote: Hi Joe,
Appreciate any advice.
Thanks for the message,
Could you please give me a call on the number 01384569942 opt 2.
Hi J1000, Joe,
I have the very same issue. Can i ask how you fixed it ?
Thank you!
BR,
Kamil
(16-01-2023, 06:25 PM)Kamil Wrote: Hi J1000, Joe,
Thank you!
BR,
Kamil
Hi Kamil,
Unfortunately we tried several things but nothing worked.
I will reply to your message.
The only thing i can think is that you have set the SBS to pedestrian opening instead of condiminum 1 (L4).
Hi Sam,
Thanks for your reply.
Do you know how I can change the sbs to allow for full opening?
Cheers again.
(03-02-2023, 12:09 PM)j1000 Wrote: Hi Sam,
Cheers again.
As standard, the SBS functions are full opening. Other than "L6" -  Step-by-Step 2 (less than 2” causes partial opening)
Thanks Sam.
Will give that a go.
(03-02-2023, 12:17 PM)j1000 Wrote: Thanks Sam.
Great, any issues let us know.
Hello
I have the same problem:
Were you able to find a solution? I suspect it is due to the “always open” feature. Which i am not sure if it can be disabled
The SBS input should allow for a closing manoeuvre when impulsed in the open position, if the gate is moving a few feet then stopping can you confirm how many times the BUS led is flashing?
  SEAV LRX-2186: gate opens a bit then stops mehsom 2 784 09-01-2026, 10:38 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,513 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 5,513 09-05-2025, 12:36 PM
  Nice wingo 5400 and MC800 engrbhadz 0 2,323 18-03-2025, 05:53 AM
Last Post: engrbhadz
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 14,211 02-12-2024, 10:40 AM
Last Post: bing
  Gate not closing thronetm 0 4,341 16-11-2024, 09:25 PM
Last Post: thronetm
  Robus Not Operating AlanWhite 3 17,131 11-09-2024, 05:00 AM
Last Post: Lee Zhang
