  • 29 Vote(s) - 3.1 Average
Beninca bob motor wiring to board
Hello, I am moving my system to accommodate new gates etc i have a Benica Brain 24 and Beninca bob Motors.  The motor has 5 connections one for positive and negative which is ok.  It has another three connections that go back to the board numbered
(3 Encoder signal)
(4 Encoder Positive)
(5 Encoder negative)
Where do these connect to on the board for motor one and motor two
the board is as follows
13 = COM
14 =SW01
15=SWC1
16=SW02
17=SWC2
18=PHOT
19=PHOTC
20=STOP
21=OPEN
22=CLOSE
23=PED
24=P.P
25=COM
Thanking you in advance
(29-10-2022, 06:30 PM)Ranch2 Wrote: Hello, I am moving my system to accommodate new gates etc i have a Benica Brain 24 and Beninca bob Motors.  The motor has 5 connections one for positive and negative which is ok.  It has another three connections that go back to the board numbered
(3 Encoder signal)
13 = COM
14 =SW01
15=SWC1
16=SW02
17=SWC2
18=PHOT
19=PHOTC
20=STOP
21=OPEN
22=CLOSE
23=PED
24=P.P
25=COM
Think i got it after reading instruction manual a bit slower but one wire i am still not sure of is no 3
(3 Encoder signal) Not sure about this one does it go to com does anyone know?   Sad  if it does would the two motors go here
(4 Encoder Positive) This is the Input close limit switch (N.C. contact) does it go SWC1 on the board as that is the input close limit switch (normally closed contact) whatever that means
(5 Encoder negative) This is the Input close limit switch (N.C. contact) does it go SW01 on the board as that is the input open limit switch (normally closed contact) whatever that means
Thanking you all in advance
THIS HAS BEEN SOLVED WITH THE HELP OF A KIND SUPPLIER
(03-11-2022, 06:41 PM)Ranch2 Wrote: THIS HAS BEEN SOLVED WITH THE HELP OF A KIND SUPPLIER
Sorry for the late response.
Glad you have got it sorted.
Glad to hear.
(04-11-2022, 09:28 AM)Michael Wrote: Glad to hear.
The problem was that the wiring diagram was for motors without encoders and limit wires and forgot to read the part about ones with mine has five positive and neutral positive and neutral com and a com wire stares you in the face if you don't need to wear glasses top right hand corner of page
Great, thank you for updating us. This has been noted.
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 61,911 09-01-2026, 10:03 AM
  Beninca BOB30ME - Not closing all the way OMH 1 540 09-01-2026, 09:54 AM
  Beninca actuator arm not moving at al Andruelectricgates 1 321 09-01-2026, 09:49 AM
  Circuit board disabled CB124 - 7 flashes Tussun 6 21,752 15-08-2025, 01:57 PM
  Beninca TOM4024E wiring Shropshire_Lad 1 2,261 14-07-2025, 01:59 PM
  FAAc xp20d wiring Neil Young 4 6,163 04-02-2025, 12:08 PM
Last Post: Neil Young
  Fried control board nickfr 3 5,656 22-03-2024, 12:53 PM
  BFT key pad not communication with digital board niall.paul@yahoo.co.uk 1 3,813 14-02-2024, 12:21 PM
  Faac 452 pcb board benner91 2 6,838 09-02-2024, 06:13 PM
  TC fault code on Q60ar control board Skydive1710 3 10,139 20-11-2023, 03:12 PM
Last Post: NormanY
