  • 28 Vote(s) - 2.86 Average
Mhouse WH2S not opening
Father in law recently purchased a new property and has asked me to look into his gate not working. When the buttons on the remote are pressed nothing happens. When I bridge the open terminals I can hear a relay on the board click (motors disengaged during testing as I didn’t have a key to reengage them)
Indicator light A is flashing one flash per second
All other indicators are off including indicator b which has nothing terminated to it
Any ideas?
Cheers
Hi Sam,
This sounds to me that the system appears ok as the EBUS is flashing once per second and when the shorting the OPEN you can hear the relay click. you will need to re-engage the motors and short the OPEN again. how many remotes do you have?
Mike
Hi Mike,
Thanks for your reply. Just the one remote, the lights on the remote are illuminating when pressed so I’m thinking the battery is fine, I also tried to re-teach the remote but the system doesn’t respond when I go through the steps to add a remote. I’m wondering if possibly the antenna is faulty I might just terminate a bit of cable to test it next time I’m out there
(07-10-2022, 12:12 AM)SamGate Wrote: Hi Mike,
Thanks for the email,
when pressing the remote control does the LED on the radio receiver illuminate? if you are using an Mhouse system or Nice home system this will be the LED next to P1, it may be due to a faulty radio receiver which can be rectified by retrofitting a standalone radio receiver.
Many Thanks
Hi Sam,
It could be a faulty remote. how old is the system?
Mike
  Mhouse sl10 not closing Mark Reader 1 6,090 13-03-2025, 09:56 AM
  MHouse Sl1 does not open v.ptohides 1 6,108 03-02-2025, 09:56 AM
  Mhouse cl2 error p2 and p3 flashes Ragnarevartov 1 7,977 20-03-2024, 11:19 AM
  Mhouse cl2 ESBus error - gate not operating yeatsie 1 10,225 30-01-2024, 10:35 AM
  Mhouse left gate blocking full open when initialising gates neil.conner 1 8,533 24-08-2023, 01:51 PM
  Mhouse SL1 won't close correctly Dartman 5 31,126 03-02-2023, 12:04 PM
  MHouse SL10 closes, but doesn't open cambo 1 8,379 19-08-2022, 09:29 AM
  MHouse SL1-10 partial close NAT 5 16,822 30-05-2022, 09:15 AM
  Mhouse WS2 Gates not closing together pauln0301 1 8,577 13-04-2022, 11:18 AM
  Mhouse WG20 Alex74 1 9,860 04-02-2022, 11:05 AM
