  • 33 Vote(s) - 3.15 Average
My Came ZM3E gates won’t open
I II cI came  back to my gates last week and they suddenly just would not reopen.
I’ve opened the came box up and all looks fine. No fault codes and the board looks in perfect condition .  I changed the 4 fuses and that did not help. When I press my fob it asks for them to open as you hear the clicking noise but then nothing responds. I changed the 2 16uf capacitors thinking they had gone with the heat but that has not fixed it.
My only thought is that the underground motors have failed . But for both to fail at exactly the same time does make me think that is not right either. I opened the underground motors and they all look fine . I put WD40 on each but still no luck.
Having exhausted all my limited options I think I need the experts please. Aany advice would be graeatly received. . Thanks
(04-08-2022, 10:16 AM)golfnut75 Wrote: I II cI came  back to my gates last week and they suddenly just would not reopen.
Good Morning,
At this point it is trial and error to pinpoint the issue, i would recommend running the gate in single mode (single motor). Take out motor 2, learn the limits and see if it runs. Then do the same with motor 2 in the motor 1 output. If one motor moves in the motor 1 output you know the other motor is the issue. If no motors move you know its the control board output failure.
Kindest Regards,
  Came ZM3E - Wont open from keypad geoff_n 2 539 09-01-2026, 03:47 PM
Last Post: geoff_n
  Gates not closing Regor23 5 7,879 03-09-2024, 12:51 PM
  ZM3E underground loop problem GhostUK 4 13,202 20-03-2024, 10:46 AM
  Came FROG-A + ZA3 controller > gates wont close safety beam endam 6 18,035 23-02-2023, 01:09 PM
  Gates out of sync frankjboyd 5 24,908 05-01-2023, 11:52 AM
  Came Gates Error code E14 janker 3 15,400 14-11-2022, 11:59 AM
  ZA3 Came gates not opening with RF device chooper 5 15,391 24-06-2022, 08:58 AM
  Came FROG - one leaf occasionally does not open fezster 3 13,282 03-08-2021, 10:07 AM
  Came Gates - power cut issues Paddy_SP 2 13,146 22-07-2021, 09:42 AM
Last Post: Paddy_SP
  CAME ZM3E Mike2006 0 13,831 28-09-2020, 07:48 PM
Last Post: Mike2006
