  • 23 Vote(s) - 3.43 Average
Robus 600 not closing fully
#11
(20-07-2022, 09:47 AM)SamA Wrote:
(19-07-2022, 08:36 AM)All Well Wrote:
(18-07-2022, 10:38 AM)SamA Wrote:
(18-07-2022, 09:05 AM)All Well Wrote:
(18-07-2022, 08:59 AM)SamA Wrote: Hi,
Thanks. Another thing: Can minor adjustment be made to the closed position. The gate stops about an inch or so short which prevents proper locking.
Of course.
Finally found the solution: At the rear end of the close contact lever there are two screws which can be loosened and the lever moved backward or forward to make the gate stop later or earlier respectively. So it is a mechanical adjustment solution!
Thanks a lot. Regards
(10-07-2022, 09:31 AM)All Well Wrote: I have a RB600 sliding gate installed working ok past one year. Lately noticed not closing fully, about an inch shorter than the mechanical stop. Have run the 'Recognition of Gate Length' program without resolution.
Any suggestions on what next?
Thank you for bringing this to our attention,
I would recommend nothing down what the Bluebus LED is doing when the fault occurs and this will give us a good indication as to what is happening, it will either be flashing once per second to resemble everything is fine or flashing multiple times and pausing to indicated a fault, we would need to know how many times it is flashing before it pauses.
Furthermore you could always try and up the force on the panel by going and changing some of your second level functions.
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 59,129 03-12-2025, 04:18 PM
Last Post: StefanP
  Beninca BOB30ME - Not closing all the way OMH 0 299 26-11-2025, 10:31 AM
Last Post: OMH
  Gate not closing thronetm 0 4,171 16-11-2024, 09:25 PM
  Robus Not Operating AlanWhite 3 16,799 11-09-2024, 05:00 AM
Last Post: Lee Zhang
  Program a 3rd party remote to Nice Robus N600 P100D 4 8,775 13-05-2024, 03:36 PM
  Nice Gates not closing StuL 1 7,887 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 15,363 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  LIFE AC4 Closing Issues dilbertdog 0 2,849 29-07-2023, 02:59 PM
Last Post: dilbertdog
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 11,785 02-12-2022, 02:51 PM
  Aria 400 - gates keep opening and closing objohnuk 1 7,952 13-04-2022, 11:32 AM
