  • 23 Vote(s) - 3.43 Average
Robus 600 not closing fully
I have a RB600 sliding gate installed working ok past one year. Lately noticed not closing fully, about an inch shorter than the mechanical stop. Have run the 'Recognition of Gate Length' program without resolution.
Any suggestions on what next?
(10-07-2022, 09:31 AM)All Well Wrote: I have a RB600 sliding gate installed working ok past one year. Lately noticed not closing fully, about an inch shorter than the mechanical stop. Have run the 'Recognition of Gate Length' program without resolution.
thanks for the message,
what is the Bluebus LED doing when this occurs? it should flash red and pulse an allotted amount of times, how many times is this flashing?
Bluebus LED is flashing normally. L1 and L2 flash normally. When i press Open and Stop together L1 and L2 flash quickly. When buttons released L3 and L4 flash and I press Stop and Close buttons. The gate opens and closes normally as per the videos. But when I operate thru remote or fixed button the gate does not close fully, stops about an inch short, Because of this the small manual gate does not latch properly.
Secondly, how can I disable the slow speed of the gate within one metre of the close stop. This was not happening before but the technician did it. Perhaps the gate not closing completely because of this slow program?
(14-07-2022, 11:13 AM)All Well Wrote: Secondly, how can I disable the slow speed of the gate within one metre of the close stop. This was not happening before but the technician did it. Perhaps the gate not closing completely because of this slow program?
Thanks for the reply,
in regards to your first point i would personally attempt to increase the force on the motor, this is done within the 2nd level of programming as per the manual.
regarding the second point the programming of the slowdown can only be done via a nice programming tool (oview) unfortunately.
Thanks. Another thing: Can minor adjustment be made to the closed position. The gate stops about an inch or so short which prevents proper locking.
Of course.
Of course.
Of course.
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 59,129 03-12-2025, 04:18 PM
Last Post: StefanP
  Beninca BOB30ME - Not closing all the way OMH 0 299 26-11-2025, 10:31 AM
Last Post: OMH
  Gate not closing thronetm 0 4,171 16-11-2024, 09:25 PM
  Robus Not Operating AlanWhite 3 16,799 11-09-2024, 05:00 AM
Last Post: Lee Zhang
  Program a 3rd party remote to Nice Robus N600 P100D 4 8,775 13-05-2024, 03:36 PM
  Nice Gates not closing StuL 1 7,887 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 15,363 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  LIFE AC4 Closing Issues dilbertdog 0 2,849 29-07-2023, 02:59 PM
Last Post: dilbertdog
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 11,785 02-12-2022, 02:51 PM
  Aria 400 - gates keep opening and closing objohnuk 1 7,952 13-04-2022, 11:32 AM
