  • 17 Vote(s) - 3.24 Average
Proteco Q60 - FH error then close after opening
Hi, I've got a Proteco Q60 dual swing gate controller. I recently had a problem where the power supply was cut to the closing photocell transmitter.   I repaired it today and the LED now goes back to '--' as expected. When I sent a close signal by linking 1-8 for a second, the LED goes to Go and the gate opens/closes as expected. However about 3-4 seconds after the gate fully opens/closes, I see FH appear momentarily on the LED, and then the gate does the reverse action.
I've tried removing all external devices and shorting the basic links (2-8, 4-9, 3-9) and testing manually by touching 1-8. Same issue - so I don't believe it's anything to do with the photocell circuit or any external switches.
Can anybody give me any indications as to what might be causing this error? The manual just says that FH is dual opening/closing photocell interruption or wiring error, but as it happens even when I have jumpers across 4-9 and 3-9 I don't believe that's the issue.
Thanks in advance for your help!
Paul
Hope you are well. We do not tend to deal with Proteco systems, I would recommend getting in touch with them directly - http://proteco-direct.co.uk/support/
- Jamie
  came bx-b clicking & not opening misssmith 1 2,961 13-03-2025, 09:57 AM
  Thalia P - BAR error devsolo 3 17,666 03-02-2025, 09:57 AM
  BFT Thalia “bAr” error. Joel23M 1 4,888 17-01-2025, 10:06 AM
  Came Frog one side wont close PmIrl 1 3,330 13-05-2024, 02:40 PM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,185 26-09-2023, 05:32 AM
Last Post: max666
  Gates Opening After Closing tht7 2 15,124 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
Exclamation Proteco Q60A stopped working xCO 0 3,260 19-06-2023, 01:03 PM
Last Post: xCO
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 9,858 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,291 12-07-2022, 11:48 AM
  proteco q60a microcontroller program arashkhan 1 5,431 17-06-2022, 01:29 PM
