  • 28 Vote(s) - 3.18 Average
Thalia P - BAR error
Hi All,
We have a BFT thalia p gate, with swing gate doors.
We have a BAR error displayed on the screen, can someone please help on how to reset this?
The gate is currently in an open position and will not close.
(21-12-2020, 11:54 AM)devsolo Wrote: Hi All,
The BAR error is generated by the safety edges, if you have wireless edges you may be get away with changing the batteries in the transmitters. Otherwise, you will require an engineer to fault find, potentially a faulty edge or cabling issue.
Electric Gates Berkshire - www.thegateco.co.uk
The Gate Company
www.thegateco.co.uk
Did you ever get this fixed? I’ve got the issue. Thanks!
Bar is an issue with a safety edge. i would check these to ensure they are functioning correctly.
  BFT Thalia “bAr” error. Joel23M 1 5,265 17-01-2025, 10:06 AM
Last Post: max666
  Deimos BT 400/600 error codes orange 0 6,088 07-12-2020, 09:36 AM
Last Post: orange
  Fav sliding gate error code plus other Adam67 0 11,323 02-09-2020, 07:06 PM
Last Post: Adam67
  Re: Error 30 tony.jay8 2 15,085 10-05-2018, 11:17 PM
Last Post: tony.jay8
  BFT Error 35 & 37 Not opening fully - SOLVED razer raz 4 52,030 14-11-2017, 04:02 PM
Last Post: razer raz
  Q60A/R error. Showing "_ " Jonas Pistolas 4 24,548 03-11-2017, 10:19 AM
Last Post: Jonas Pistolas
Question Proteco q80s Error 44 Cphats 1 12,587 13-08-2017, 11:15 PM
Last Post: gerardo
  BFT Deimos BT Error Codes rajesh 1 21,581 05-06-2017, 11:07 AM
