  • 21 Vote(s) - 2.76 Average
Nice TOO7500/ Mindy A60 Installation Problem
Hi All, please bear with me as I’m a keen DIYer not a professional gate installer.
I’ve just installed a Nice 7500 double gate opener with a Mindy A60 control panel.
However, I can’t get the motors to move. I’ve wired everything up as per the instructions but no movement when I press the control.
The LED on the control board is on and flashing and it does a double flash every time I press the control, so I think it’s getting the demand signal okay.
Reading another thread it says put a bridge between terminals 20-22 (common to
Stop). Is this correct? There is currently no wire in 22 which i assume is described as a normally closed input.
Just don’t want to damage the panel by connecting the wrong terminals together.
Thanks for your assistance,
Woody
Resolved. I plucked up the courage and connected together terminals 20-22 and it worked, should anybody else have the same issue.
  Nice LFAB occasionally failing open DaveHG 3 10,098 20-08-2025, 01:52 PM
  Nice Control unit passcode removal Andruelectricgates 1 4,050 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 4,724 21-05-2025, 10:54 AM
  Looking for help with oldschool NICE gate motor gatekeeper 0 5,444 16-02-2025, 05:16 PM
Last Post: gatekeeper
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,929 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 8,375 10-12-2024, 10:31 AM
Last Post: dmrgate
