  • 20 Vote(s) - 3.25 Average
Liftmaster MYQ Internet gateway
Hello,
I just bought the MYQ INTERNET GATEWAY 828EV.
I was able to install and connect the gateway to my garage motor unit (model LM80 EVS).
However i'm only able to open the garage.
when the garage is already open, i'm unable to close the garage via the app or website.
(getting error like: device not responding, please try again later)
anyone can help me out here? :-)
To be able to remotely close the door through the app you require photocells to be installed. They are the 771E photocells and Liftmaster/Chamberlain have done this so you are unable to close the door if there is an obstruction blocking the photocell beam.
(24-04-2020, 09:11 AM)RyanB Wrote: Hi,
Hello Ryan, thank you for the info.
I have a camera in the garage, so no need for those photocells in my case and just wondering -- is there is a way of working around this limitation with some kind of garage opener settings / connections, etc.?
My garage opener model is Liftmaster LM100EVF, would be appreciative for any kind of advice.
Hi Arnold,
You would still need to connect the 771E to the operator to fully use the MYQ for the door to close I'm afraid as there are no settings you can change.
Mike
(04-10-2024, 10:44 AM)Michael Wrote: Hi Arnold,
Mike
Hi Mike, thanks much for the reply.
Obviously not an ideal situation, with no use for these sensors sounds like I'll need to be looking for some 3rd party solutions like meross, etc.
  LiftMaster SL400EVK & 722e Failsafe Tucks27 4 323 Yesterday, 10:52 AM
  Liftmaster LA400 Defender 6 22,280 03-08-2023, 12:26 PM
Last Post: Torantrieb
  odd liftmaster scs300-24 scopie88 3 21,461 13-04-2022, 10:20 AM
  Liftmaster MYQ Internet Gateway Registration/Connection issues! Carmody 0 19,382 09-03-2021, 02:46 PM
Last Post: Carmody
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 23,479 22-02-2021, 08:48 PM
Last Post: russ
  Liftmaster CB1 gates started to open themselves telnet123 4 35,391 01-01-2020, 09:43 AM
Last Post: pronosoft
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 35,628 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  Liftmaster sliding gate Kar1e 1 20,104 08-08-2017, 11:23 AM
  Liftmaster SCS300K - stop/go mtuk100 1 18,605 18-04-2017, 09:31 AM
  LiftMaster SUB300M + CB11 fault jonesy1991 0 12,397 25-01-2016, 02:51 PM
Last Post: jonesy1991
