  • 407 Vote(s) - 2.87 Average
T291 Hydraulic Ram - What Oil
We lost some oil from our T291 Hydraulic ram through the manual override (basically gate was pushed when the override key was used and the valve was loose - and a load of oil squirted out).
What is the recommended oil to replace this?
Thank you.
Check the specification on the can if available - should meet a DIN or ISO spec.
If not available then ISO viscosity grade 15 - such as Tellus T 15 will work fine.
