T291 Hydraulic Ram - What Oil - Printable Version +- Electric Gates, Garage Door, Access Control, Smart Home & Security Forums (https://www.gateguide.co.uk) +-- Forum: Gate Automation and Installation Help (https://www.gateguide.co.uk/forumdisplay.php?fid=1) +--- Forum: Gibidi Gate Openers (https://www.gateguide.co.uk/forumdisplay.php?fid=19) +--- Thread: T291 Hydraulic Ram - What Oil (/showthread.php?tid=105) |
T291 Hydraulic Ram - What Oil - Guest - 16-10-2009 We lost some oil from our T291 Hydraulic ram through the manual override (basically gate was pushed when the override key was used and the valve was loose - and a load of oil squirted out). What is the recommended oil to replace this? Thank you. RE: T291 Hydraulic Ram - What Oil - TheOilMan - 20-07-2011 Check the specification on the can if available - should meet a DIN or ISO spec. If not available then ISO viscosity grade 15 - such as Tellus T 15 will work fine. |
