  • 24 Vote(s) - 3.13 Average
Genius board (FAAC) help
Hi forum,
My Genius board has no power going to it. I checked the mains supply in and its live but nothing on the control board. It looks like the board in the back of the box has gone. Does anybody not what part this is? It's not the control board, its the board behind that one.
Sam
[Image: 565KFWQ]
Image of the board: https://ibb.co/565KFWQ
(07-03-2020, 02:38 PM)Kingkelly77 Wrote: Hi forum,
Sam
[Image: 565KFWQ]
Hope you are well,
do you have the model number of this board it should be printed on the board somewhere or on the board transformer.
it may state 455D.
please provide.
if there has been an electrical short on any of the panel it may have caused damage to the actual main PCB meaning the board will need to be replaced.
have you also checked the panel fuses.
Regards Joe
Sam
[Image: 565KFWQ]
Probably a slug on the back of the board. You could remove the board out the cabinet and look on the rear. Ensure the power is off!!!!
Access Control Ltd
0333 5776227
Sam
[Image: 565KFWQ]
out of curiosity have you checked the fuses on the board at all?
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 6,610 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,604 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,294 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,342 13-03-2025, 10:05 AM
Last Post: robhight
  Genius Ja592 - repeated failures john@worldhq.com 0 2,790 22-08-2024, 08:49 AM
Last Post: john@worldhq.com
  FAAC problem dennisoates 0 3,634 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,825 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,434 18-03-2024, 01:20 PM
Last Post: RXH
