  • 245 Vote(s) - 2.98 Average
BFT Rigel 5 with a Z-Wave Relay?
Hi guys,
I'm looking to wire up a wireless relay into my old Rigel 5 box that controls our gates.
I've had a scan through the manual and roughly figured out where I should be heading but i'm still a little confused.
I want to use something like, or similar to these
https://www.amazon.co.uk/Z-Wave-2%C2%A0S...baro+relay
http://www.vesternet.com/z-wave-fibaro-r...t-1-2-5-kw
They power off mains, so I was thinking I could use 10-11 on the board for Live and Neutral.
Then how would I send the "start impulse" I imagine I would wire NO1 from the relay in the first image to perhaps 32? "OPEN", or would it be 28?
There is another product from Fibaro called the Roller Shutter 2 which rather than just trigger the "start impulse" could technically open and close the gates, presumably that would go into 32 for open and 33 for close? Whilst that would give me more control, id then have to program my home automation system (SmartThings in this case) to also close the gates behind us, it makes more sense to let the Rigel 5 do this as its been doing successfully for years - and program SmartThings to "press" the start impulse again if we want it to keep the gates open at any point.
Looking forward to input from those that know the Rigel panel - we did have a push button door bell wired up to this at some point, so i'm assuming its actually fairly easy to send start the "start impulse" command.
I've been told on the SmartThings forum the Mimolite is the thing to use for this.
It has a COM and N.O. output, so to trigger the start impule I assume I want the COM to go to 27 and the N.O. to 28?
Hopefully someone could confirm that.
Anyone?
Dan
I see on the SmartThings forum that you got the MimoLite working with the Rigel 5. Can you confirm the connections, as you mention 2 different ones in your various posts?
thanks
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,423 21-07-2025, 06:54 AM
Last Post: jojo351
  BFT Rigel 5 Talonfinger 0 2,191 26-03-2025, 12:07 PM
Last Post: Talonfinger
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,569 03-02-2025, 11:29 AM
  BFT Rigel 5 - Phot message robs999 2 5,049 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 5,354 30-10-2024, 12:54 PM
Last Post: Vaf888
  BFT Rigel 5 issue Adamit 0 2,885 17-05-2024, 10:28 AM
Last Post: Adamit
  Just Got A Rigel 5 and need HELP!!!! rapley 2 18,202 04-05-2024, 12:47 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,458 04-01-2024, 10:21 AM
  smart relay BFT ALTAIR halt23 1 3,699 13-11-2023, 11:45 AM
  smart relay BFT ALTAIR halt23 1 3,592 13-11-2023, 11:45 AM
