  • 379 Vote(s) - 2.83 Average
cb24
I have a CB24 gate opener and it's been ok since I fitted it two years ago - following a minor reset the gate has developed a small glitch. It is fitted with a solenoid latch to lock the gate when it closes but it has started to hang on energised for a couple of seconds when it closes and misses the latch since there is a slight bounce back when the gate contact the stop. This means the gate is not in the lock position when it finally does de energise. What is the correct format for programming the solenoid since the book only gives it for Maglock which is different.
JWils Wrote:Hi
The CB24 is designed to work best with Magnetic Locks which work in a completly opposite to the Solonoid lock.
The Gate system need to be set as to not have any bounce back so the lock will engage this is just a case of trial and error programming it to best effect there is no adjustments for the time the lock engages and dissengages.
  CB24 delay to close random fault stuartdsutton 0 10,180 23-09-2015, 11:38 AM
Last Post: stuartdsutton
Rolleyes Chamberlin Liftmaster Professional (CB24 & dual LYN400.24v) SDL 4 33,662 29-12-2013, 02:26 PM
Last Post: Tussun
  Liftmaster Professional CB24 / LYN400 24v - RPM Reversal Error jrhodes310 1 15,455 20-08-2012, 09:40 AM
  Wiring relay to CB24 magga 4 25,558 01-08-2012, 06:35 PM
Last Post: magga
  cb24 photocells devonaloan 1 13,563 28-11-2011, 05:57 PM
  Liftmaster CB24 key switch Mel1962 2 18,965 25-10-2011, 09:52 PM
Last Post: Mel1962
  CB24 Problems andydday 3 22,224 06-02-2011, 11:39 AM
Last Post: Guest
  CB24 Kit with a single set of photocells JD1765 1 22,963 07-06-2010, 10:04 AM
  CB24 / EasyBKA cliff finch 2 17,801 25-03-2010, 09:25 PM
Last Post: cliff finch
  CB24 Stopped Responding TimL 5 29,082 19-11-2009, 05:22 PM
Last Post: adambrown81
