  • 20 Vote(s) - 2.85 Average
Hello - Another Proteco Q60A/R Question!
Hi there,
In a desperate attempt to avoid forking out £150 for a replacement board, which might not even fix the problem, I'm wondering if anyone can possibly help!
After years of service, and a few niggles, I'm getting the 'N1' motor 1 error. I've already tried the following:
1) Checked the circuit board for any visible signs of corrosion, damp, short circuits, or fried components - None
2) Checked all the wiring into, and out of, the control unit, and to the motors - Looks fine
3) Checked and tightened up all the wiring into the terminal blocks - Checks out
4) Checked the torque settings on the motors - Both maxed
5) Switched it to single motor operation, and tested the motors individually (i.e. just 13/14/15, and then plugging 16/17/18 in the 13/14/15) - It carries on saying 'N1' in both cases.
I can hear the switch/solenoid/motor coming on for a fraction of a second, but then it immediately stops.
Given swapping the motors over made no difference, it seems unlikely to me that both motors have failed at the same time. And, by the same logic, the capacitors are unlikely to be the problem. My current theory is that there is a problem with the board itself, and if so, I'll need to replace it.
Any suggestions would be fantastic!
Many thanks - I know it's old kit, but it still sad when it's beyond repair.
SawboMan
Update - changed the motherboard (kept the capacitors), and it’s now fixed!
Happy to pay £150 for that.
(08-07-2022, 05:04 PM)SawboMan Wrote: Update - changed the motherboard (kept the capacitors), and it’s now fixed!
Sorry for the delay in reply.
Glad to hear you have rectified your issue.
  q60a stevea 1 2,382 23-08-2024, 12:14 PM
Last Post: stevea
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,185 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,260 19-06-2023, 01:03 PM
Last Post: xCO
  Replacement Q60A board? ndyhzlwd 1 5,467 10-02-2023, 03:19 PM
  First Post.. With question Yos Sam 5 10,237 04-11-2022, 09:27 AM
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 9,858 26-08-2022, 03:42 PM
  Proteco Q60 - FH error then close after opening Needlerp 1 5,741 24-06-2022, 09:54 AM
  proteco q60a microcontroller program arashkhan 1 5,431 17-06-2022, 01:29 PM
  Proteco Q60 AR ...Fob wont program Shane1 0 3,722 12-01-2022, 08:13 PM
Last Post: Shane1
  Proteco Leader N1 problem Luc Bevers 0 4,113 22-10-2021, 09:57 AM
Last Post: Luc Bevers
