  • 22 Vote(s) - 2.82 Average
Nice Robus Don't Auto Close!!!!
Hi freinds .. am new here .. My Robus 600 holds open .. it does'nt close after the pause I set for 5 seconds .. and there are an 8 flashes in the bluebus LED though I don't use it .. I use only normal photocells connected to OPEN slot .. Anyone knows how to fix this??!!!!
Hi Ali,
8 flashes from the bluebus indicates A command that does not permit other commands to be
performed is already present.
Check the type of command that is always present; for example, it could be a
command from a timer on the “open” input.
Do you have anything else connected to the board that could be causing this?
Mike
  Nice Robus closing after photo Nexur 1 6,959 26-08-2025, 01:47 PM
  Nice LFAB occasionally failing open DaveHG 3 9,198 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 7,644 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 3,342 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 3,914 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 4,108 09-05-2025, 01:07 PM
  Mag-lock not activating after close benkay 4 8,917 13-03-2025, 04:19 PM
Last Post: ldkerlukeHome
  Looking for help with oldschool NICE gate motor gatekeeper 0 4,669 16-02-2025, 05:16 PM
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 2,983 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,070 10-12-2024, 11:29 AM
