  • 140 Vote(s) - 3.04 Average
CB124EV Problem
Hi I've fitted a new CB124EV board to replace an old CB24.
the problem I have is when setting up all is good both gates go through the learn cycles but after when I press the button to open the gates only motor1 gate opens.
Dill switch is set to two gates
I've even swapped the wiring from motor1 to motor2 and motor2 to motor1 to prove the motors, still only the gate in motor1 opens
any help would be greatly appreciated
is the motors having micro switches ?
Open the gate manually at halfway and press the remote control
Best RegardsĀ
TomĀ
  Photocell Problem marcoos_1 4 28,798 04-01-2024, 10:23 AM
  Master to slave remote problem Dingerb 0 3,863 24-12-2021, 01:26 PM
Last Post: Dingerb
  Proteco Leader N1 problem Luc Bevers 0 4,345 22-10-2021, 09:57 AM
Last Post: Luc Bevers
  Proteco gates with photocell problem. Shane1 0 4,199 09-10-2021, 07:56 PM
Last Post: Shane1
  BFT ULTRA BT A50 problem cayres 0 4,192 13-04-2021, 08:19 AM
Last Post: cayres
  CB124EV flashing learn light won't go out rodean 0 5,531 07-09-2020, 09:06 PM
Last Post: rodean
  Beninca RI 6E Problem leonardermo 0 6,426 29-04-2020, 08:45 PM
Last Post: leonardermo
  Genius Gate System Problem grasshopper 1 14,822 01-07-2019, 09:39 AM
  Genius JA574 problem jeeter 0 6,742 02-05-2019, 01:13 PM
Last Post: jeeter
  Q60A/R motor problem Johnmc 12 57,335 17-01-2017, 08:15 PM
