  • 19 Vote(s) - 3.16 Average
Is there a way to disable the Open hold feature on the NICE control unit ? the issue I have at one of our client sites is the gate is opened remotely via a Paxton entry system/ fob entry, nobody waits for the gates to fully open but as they pass through they trigger the induction loop in the ground on the inside ( for auto opening when leaving). This sends a second open signal which of course then holds the gates open.
Thank you for the enquiry.
Hi Ben,
The control unit is a MCA1 ITEM: MCA1R10 is the information on the label on the front.
The issue is the hold open, it can be triggered by a second "open" request from the Paxton reading a card, or by a vehicle driving inwards and over the induction loop following the first open request, i have witnessed the second "open" command and the gates do remain in the open position until a further "open" request at which point they fully open then close after the timeout.
I also have another site with a MC800 control unit, would the oview programmer work for both units ?
(07-09-2023, 03:16 PM)paul@blxnetworks.co.uk Wrote: Hi Ben,
It is possible that the gate is receiving a second command then, which will result in the gates holding open.
To fix this condominium mode / apartment block would need to be activated on your step-by-step function. Instructions on how to do this can be found on page 8 of the PDF document.
https://manuals.easygates.co.uk/PDF/nice/D00011568.pdf
Regarding if the oview will work on both MC824H and the M800, yes it will as both panels have a IBT4N connection which is needed when plugging the Oview in.
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 61,866 09-01-2026, 10:03 AM
  How to disable Came DIR10 photocells after traffic accident Howardy 3 3,627 09-07-2025, 11:36 AM
  Nice Swing Gate Opener nicenotnice 0 4,665 18-03-2025, 06:40 AM
  Nice wingo 5400 and MC800 engrbhadz 0 2,317 18-03-2025, 05:53 AM
Last Post: engrbhadz
  Program a 3rd party remote to Nice Robus N600 P100D 4 9,331 13-05-2024, 03:36 PM
  Nice MC824H gate stuck open Markp80 1 5,971 13-05-2024, 02:32 PM
  Rigel 5 , gates won't open Nameloc 4 10,261 04-05-2024, 12:41 PM
  Came ZA3 gates stuck open Ivorwindybottom 0 3,091 18-02-2024, 06:29 PM
  Nice Gates not closing StuL 1 8,257 24-08-2023, 01:34 PM
