  • 17 Vote(s) - 3.18 Average
Nice Walky on 24v
I was hoping to use the Walky to open a small swinging gate and already have 24v to the area. It looks like the Walky has the option to run on battery back-up (14.4v) or via the Solemyo solar (24v I believe) either of which can be plugged into the optional power input on the control board.
Just wanted to confirm that should work with 24vdc or if anyone has something similar?
With the Walky system, you would need 230 VAC at the control panel, this will be stepped down to 24v to power the motors/accessories etc.
Many Thanks.
  Nice LFAB occasionally failing open DaveHG 1 1,388 15-08-2025, 02:11 PM
  Nice gates don’t close after the ambient temp is high Howard 2 1,068 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 1,326 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 1,818 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 2,022 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 2,703 16-02-2025, 05:16 PM
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 2,113 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 6,817 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 5,071 10-12-2024, 10:31 AM
Last Post: dmrgate
  Nice O-Box Software Andruelectricgates 1 3,326 09-12-2024, 12:52 PM
