  • 12 Vote(s) - 4.08 Average
Nice Walky 2024
Hi all,
Looking for some advice from those that might have trodden this path before.
I am buying a property on a housing estate, which has metal manual gates which I want to switch out for wooden electric gates. The challenge I have is on a couple of fronts;
1. Relatively close to one of the pillars is a drain cover. I contacted a few companies that fit solid hardwoord gates that want 600x600 room to concrete in a post to support the gates due to the weight
2. On the second pillar, it is shared with the house next door, with the fence that splits our drive landing in the middle. Giving only 160mm on the back on my side.
So trying to find a solution, I looked at softwood gates (they are only 1300 wide each side, so weigh roughly 60/70kg) and mechanisms that don't need a huge depth. According to the specs, the Nice Walky 2024 only needs 80mm to attach the motor, and 120mm with the reduced arm.
My question, is has anyone fitted this sort of set up and achieved good results. By which I mean reliability/speed.
Also, any advice on how I might find a fitter that has worked with Nice equipment locally to help me would be much appreciated (Hertfordshire area)
  Nice LFAB occasionally failing open DaveHG 1 1,388 15-08-2025, 02:11 PM
  Nice gates don’t close after the ambient temp is high Howard 2 1,068 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 1,326 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 1,818 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 2,022 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 2,703 16-02-2025, 05:16 PM
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 2,113 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 6,818 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 5,073 10-12-2024, 10:31 AM
Last Post: dmrgate
  Nice O-Box Software Andruelectricgates 1 3,326 09-12-2024, 12:52 PM
