  • 147 Vote(s) - 3.29 Average
Lead gate only opening a few inches.
Rolleyes
Hi Im a DIYer
My system - Bft SubR. Rigel 5 control board.
My lead gate is only opening a few inches then stops.
Do I need to top up the hydraulic oil.
When topping up hydraulic oil do I need to isolate the mains power supply and use the Triangle key to disengage the hydraulics. Im afraid hydraulic oil will spurt out under pressure from fill port.
Yes the oil does sound like it could do with topping up, the problem you have is that air may be inside the motor which will still continue to cause a problem even after topping up. It sounds to me like you could do with a potential service by a gate automation installer before it becomes quite costly.
Hi Sav
Thanks for your reply. I ordered hydraulic oil and when I went to top oil up noticed that it is Full.
The air lock might be the problem. Can you tell me where the bleed valve is and how to go about bleeding.
I had this motor repaired by service engineer only few months ago. He had motor & pump away for weeks and when he reinstalled again the gate was half as slow opening & closing then now only opening few inches.
I will not go back to this firm as very dissapointed with their work, they didnt even have a grease gun and didnt service gates when i asked.
  SEAV LRX-2186: gate opens a bit then stops mehsom 0 145 10-12-2025, 09:42 AM
Last Post: mehsom
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 59,128 03-12-2025, 04:18 PM
Last Post: StefanP
  Help me identify this mystery gate opener alpha 5 5,111 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,027 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 5,023 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,651 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,509 18-03-2025, 06:40 AM
  came bx-b clicking & not opening misssmith 1 3,103 13-03-2025, 09:57 AM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 13,213 02-12-2024, 10:40 AM
  Gate not closing thronetm 0 4,171 16-11-2024, 09:25 PM
