  • 18 Vote(s) - 3.56 Average
Beninca TOM4024E wiring
Can anyone advise what cable I need to run from the control unit to the motor. It seems to say in the instructions 4 x 1.5mm for the power, 3 x 0.5mm for the encoder and 2 x 1mm for the Photocell Transmitter.
I understand the cable for the Photocell, but does the arm really need 2 separate cables, or can it be a single 7 core cable?
(11-07-2025, 08:28 PM)Shropshire_Lad Wrote: Hi,
Thank you for your message.
I would recommend following the manual in this instance. They state as you mentioned a 3 core cable 1.5mm2 for the power cables and 3 core cable 0.5mm2 for the encoders for the 40ME, the encoder cable most likely needs that smaller CSA of cable for communication reasons as it is mostly like data/pulses travelling through that cable.
  FAAc xp20d wiring Neil Young 4 5,155 04-02-2025, 12:08 PM
Last Post: Neil Young
  Beninca du.it14n Parko 1 3,731 24-08-2023, 01:38 PM
  BFT gate and Hikvision wiring help Gowrie 0 5,846 26-05-2023, 02:05 AM
Last Post: Gowrie
  Beninca bob motor wiring to board Ranch2 6 12,282 18-11-2022, 09:59 AM
  Beninca BOB21m Photo cell issue Rossm1987 1 7,217 02-05-2021, 12:39 PM
Last Post: Rossm1987
  Beninca motor capacitor ? OferD 0 4,949 22-02-2021, 06:02 PM
Last Post: OferD
  Beninca Bob Noisy johnthecandle 0 6,442 19-11-2020, 11:43 PM
Last Post: johnthecandle
  faac (Mac) 462df end switch wiring kenneth 0 5,619 13-11-2020, 05:43 PM
Last Post: kenneth
  Wiring help meditek 0 5,028 07-11-2020, 01:59 PM
Last Post: meditek
  Beninca RI 6E Problem leonardermo 0 6,074 29-04-2020, 08:45 PM
Last Post: leonardermo
