  • 21 Vote(s) - 2.95 Average
Gate continues trying to open
Hello All--
New faac 402 with 455 d control board:  Gate continues trying to open more after stopping and reaching approximately 90 degrees.
For about 20 seconds it will make loud humming sound, like it is trying to open.  After the 20 seconds it will go into the pause mode and subsequently close. Why is the arm doing this?  The 455 d manual does not seem to address.  Appreciate any assistance.
Thank you,
Kevin
(04-09-2022, 05:59 PM)tjtj6554 Wrote: Hello All--
Thank you,
Kevin
Good Morning,
It sounds like the board hasn't learnt its limits or lost its memory and is over running. If you go into the first level of parameters and select time learning this will relearn the limits.
Page 17 section 5.1 for reference.
https://manuals.easygates.co.uk/PDF/misc/455-D.pdf
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 4,788 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,145 26-08-2025, 02:23 PM
  FACC sliding gate not responding. Kipod 2 4,347 09-12-2024, 09:24 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,635 18-11-2024, 11:48 AM
Last Post: robhight
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,088 22-04-2024, 03:21 PM
  Latch open with Videx GSM DP86 3 8,710 20-09-2022, 08:06 AM
  Faac gate opens when photo cell beam is broken Stephen Q 5 20,382 29-03-2021, 01:53 PM
Last Post: Stephen Q
  Fine tuning gate stopping point jwcgc629 0 7,615 11-12-2020, 04:53 PM
Last Post: jwcgc629
  FAAC Gate Issue asifrana 0 11,650 26-07-2020, 10:53 PM
Last Post: asifrana
  Gates open /won't close mag1173 0 9,268 09-07-2016, 03:46 PM
Last Post: mag1173
