  • 348 Vote(s) - 2.88 Average
CAME double gates - one side closes but will not open
Hi. I am new to this forum. We have an older model CAME ATI 167674 external automatic opening system for wing gates. Left side will close using the keyfob but will not open. Can open manually and it closes every time. The right side works fine. We are located in a remote area. Can anyone provide troubleshooting steps to fix what is causing the failure or determine what part needs replacing. Thanks in advance.
This is very odd behavior and there is a problem somewhere on the system. To check whether it is on the board or on the arm, I would swap the motor outputs over on the board. So unplug motor 1 and plug into the motor 2 output and vice versa. If the problem persists on the same leaf, then you will know that it is a problem with the arm. If the problem swaps onto the opposite leaf, then the problem lye's with the control panel.
Hope this helps!
Kindest Regards,
Dave
(02-08-2013, 04:30 AM)crliving Wrote: Hi. I am new to this forum. We have an older model CAME ATI 167674 external automatic opening system for wing gates. Left side will close using the keyfob but will not open. Can open manually and it closes every time. The right side works fine. We are located in a remote area. Can anyone provide troubleshooting steps to fix what is causing the failure or determine what part needs replacing. Thanks in advance.
  Gates not closing Regor23 5 7,353 03-09-2024, 12:51 PM
  Came FROG-A + ZA3 controller > gates wont close safety beam endam 6 17,252 23-02-2023, 01:09 PM
  Gates out of sync frankjboyd 5 24,447 05-01-2023, 11:52 AM
  Came Gates Error code E14 janker 3 14,809 14-11-2022, 11:59 AM
  My Came ZM3E gates won’t open golfnut75 1 10,782 12-08-2022, 08:40 AM
  ZA3 Came gates not opening with RF device chooper 5 14,950 24-06-2022, 08:58 AM
  Came FROG - one leaf occasionally does not open fezster 3 13,015 03-08-2021, 10:07 AM
  Came Gates - power cut issues Paddy_SP 2 12,847 22-07-2021, 09:42 AM
Last Post: Paddy_SP
  Came Double Swing Gates opens by itself for some centimeters risp73 0 10,238 19-06-2020, 06:19 PM
Last Post: risp73
  Came gates Ring8180 1 85,349 10-07-2019, 10:39 AM
