  • 3 Vote(s) - 2.67 Average
Replacement remote
Hi all. After some advice from the knowledge pool.
I have electric gates on my drive that I inherited with my house.
I need some new remotes and from what I can find they are 433.92mhz rolling code.
Apologies if this has been asked but I have searched and can’t find the answer.
So my question is can I use any remote that is 433.92 rolling code.
Thanks in advance
Sliding Gate opener is Sfeomi.
Hi Chindley,
You would need to get a remote that is compatible with your current system. finding the model number of your system would be a real help to ensure you get the correct remote.
If this fails and you cannot find replacement remotes either due to them being discontinued or just cannot find a suitable replacement. you could always look along the lines of a receiver upgrade kit that will allow you to use remotes that are compatible with the receiver instead of the gate opener.
receiver upgrades would most likely be wired into the push button terminals on the board to allow it to open your gates.
it would be best if you can find the model number of your opener first to refer to the manual in both cases whether finding replacement remotes or where to wire a receiver upgrade into the board.
Matt
  Program a 3rd party remote to Nice Robus N600 P100D 0 18 Yesterday, 05:51 PM
  Replacement Above Ground Mechanism Advice Amadeus 0 612 29-07-2023, 12:47 PM
Last Post: Amadeus
  Controller CL20S replacement Kaala1 6 5,010 15-03-2023, 09:23 AM
  Replacement Q60A board? ndyhzlwd 1 1,979 10-02-2023, 03:19 PM
  Master to slave remote problem Dingerb 0 1,636 24-12-2021, 01:26 PM
Last Post: Dingerb
  V2 Phox 2-Channel Remote Control moldy1 3 11,746 02-04-2020, 12:39 PM
  Help programming SUN 433 4CH remote jedimatafez 2 8,281 24-02-2019, 08:04 AM
Last Post: jedimatafez
  Programming remote Luke 1 8,270 16-05-2018, 07:38 PM
Question Impulse versus permanent “push button” remote control ajberna 1 10,914 08-08-2017, 02:02 PM
  Replacement Daitem D5131 Ningana 0 7,025 18-06-2016, 07:03 PM
Last Post: Ningana
