  • 2 Vote(s) - 1.5 Average
FAAC GATES NOT CLOSING
Hi.
I have a set of FAAC gates. They work on a master switch a sim card opening system where my phone opens the gates.
Everything was working perfectly until last week when the gates opened and closed ok but when the photocell was tripped the gates wont close unless you dial the number or flick the master switch.
I found the little white wire had broken off but cannot find the correct terminal to connect it back to.
Even with the wire not connected the gates open and close as they should. They only stop when the photocell is tripped.
Tearing my hair out in 30 degree heat.
Any help greatly appreciated.
I've images of the board and relay that triggers the sim card. Broken wire circled in red.
  FAAC 402 Tom France 1 8,090 10-06-2019, 03:55 PM
Last Post: Tom France
  GIBIDI gate motor closing problem davidcunningham 0 7,951 26-04-2019, 07:46 PM
Last Post: davidcunningham
  Hi All BFT ALTAIR-P gates not closing michaelo76 0 5,163 13-08-2018, 05:47 PM
Last Post: michaelo76
Shy FAAC 452 Ken cooper 1 12,911 05-06-2018, 05:57 PM
  Just found you my gates are stuck open bomitie 1 7,574 30-04-2018, 01:56 PM
Last Post: Tim
  Bft gates (im not technical) chriscovbft 1 8,686 12-04-2018, 03:52 PM
Last Post: Tim
  Failure of Swing Gates to Close Auto A C John 1 9,230 28-09-2016, 09:23 PM
Last Post: MWJONES
Wink Geniss Gates with Genius BRAIN 03 Control Board 4LPS 3 17,603 10-08-2015, 09:31 PM
Last Post: 4LPS
