  • 221 Vote(s) - 3.07 Average
Geniss Gates with Genius BRAIN 03 Control Board
Wink
Hello Everyone,
I have just joined the forum so a Newbie Smile
After reading previous threads I haven't found the same problem so I am hoping you can ALL help. Thanks in Advance.
Situation:
We moved to a place with electric gates approx. 18 months ago.. Nice to have and feels secure.
I have recently come across my first problem which seemed to happen around the time of heavy rain a few weeks ago (unsure if there is any connection):
My Gates are staying constantly open displaying "tc" on the control board.
Before the problem occurred, when you walked up to the gate between 7am to 8pm (these are the timer settings) they would open and close automatically when you walked/drove passed the sensors. However, the gates now remain completely open during these hours.
However, if I turn the timer off (Timeguard FST11(24HR,
FST17 (7DAY) the gates close and they can only be opened using the remote fob. Or if I disconnect the wire from the timeguard to the control board the gates close.
During the night, the timeguard switches to "off", and the gates remain closed until timeguard switches to "on".
I have taken photos of the Genius Brain 03 and Timegaurd unit if that helps.
Many Thanks
Genius Gates
Hi ALL,
After some further investigation it has been narrowed down to the outside "Infra Red Photocell".
Currently its a SWG-0142 photocell no longer available
Can anyone recommend a replacement..
Many Thanks
AL
Hi Al,
It sounds to me that the timers output may be wired in series to any of the other connected devices which when switched off, won't allow for a full circuit to be made, hence why there would only be function from remote's rather than anything hard wired.
As for the photocells, this board uses pretty generic relay cells which can be purchased at the following address. If you need any more info, please let us know!
http://www.easygates.co.uk/product_info....ductID=136
Cheers,
Dave
(04-08-2015, 09:26 PM)4LPS Wrote: Hi ALL,
Many Thanks
AL
Dave Blake
Hi Dave
I have got a set of photocell sensors but struggling to it them working... I know its the configuration and dip settings I need to get correct. But need HELP..
My old sensors has 5 connections (C=Blue, NO=yellow timer wire)
V- V+ NC C NO
My new sensors have
V- V+ NC NO
AM guessing the Blue wire is the switch. Now I can get it work where the gates close when I break the beam sensor.. soon s I move they reopen. SO I guess I need to swope something around...
If I manually connect Blue and yellow the gates open while they are connected.
Many Thanks
Al
  FAAC GATES NOT CLOSING Slick19000 0 3,267 21-07-2021, 01:45 PM
Last Post: Slick19000
  Hello Looking for gate control help everettc4 1 6,498 05-02-2021, 01:12 PM
  Wiring control panel apritech mach2 230v brian 32 123,012 27-11-2019, 10:15 PM
Last Post: brian
  Hi All BFT ALTAIR-P gates not closing michaelo76 0 5,163 13-08-2018, 05:47 PM
Last Post: michaelo76
  Just found you my gates are stuck open bomitie 1 7,574 30-04-2018, 01:56 PM
Last Post: Tim
  Bft gates (im not technical) chriscovbft 1 8,684 12-04-2018, 03:52 PM
Last Post: Tim
  Failure of Swing Gates to Close Auto A C John 1 9,230 28-09-2016, 09:23 PM
Last Post: MWJONES
  Q80A Control Box Paj 0 7,118 03-09-2015, 07:36 PM
Last Post: Paj
