  • 2 Vote(s) - 2.5 Average
But Rigel 5 and Deane a15 cells
Hi there
I am having a nightmare with the above. I have the gate, fobs and keypads working fine. When I try to connect the cells they don’t work. I have been through all the combinations listed in the manual with no joy. Can anyone please give me a definitive wiring description and advise as to what I need to set the control board to. I have 2 pairs of the cells in the system. Thank you in advance.
What is the desired configuration of your photocells?
Would you like them to work close only, open and close or open only?
Thanks for the reply
I would like them to work open and close, with stopping and then continuing without full reverse.
If I connect the front cells with no test in logik menu they work. Same goes for the rears. If I connect both then neither work.
  Just Got A Rigel 5 and need HELP!!!! rapley 2 13,289 04-05-2024, 12:47 PM
Last Post: Alee
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,310 04-01-2024, 10:21 AM
  Rigel 6 conections Muttlymoo1979 0 1,420 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Er 10 code on RIGEL 6 control unit Eddiew 1 2,805 05-01-2023, 11:53 AM
  BFT Rigel 6 - Buttons suddenly stop working RobE 5 4,947 10-10-2022, 01:10 PM
  Rigel 6 - doors do not stay open Poweroftaxi 1 9,364 13-04-2021, 02:41 PM
  Bft rigel 6 PHCL tidoh2021 1 11,865 12-03-2021, 07:31 PM
Last Post: russ
Smile Rigel 5 Manual override Stramorebees 0 10,137 20-09-2020, 12:03 PM
Last Post: Stramorebees
  BFT Rigel 5 Issue kw1 0 9,667 16-08-2020, 02:04 PM
Last Post: kw1
  Wiring Compacta photocells to Rigel 5 rjmoore 0 11,062 11-05-2020, 06:51 PM
Last Post: rjmoore
