  • 7 Vote(s) - 2.57 Average
Nice A400 automatic search
Hey everyone,
After days of avid searching the Internet for my problem, I stumbled upon this excellent forum.
I'm hoping I can get some help with my issue, or at least get some pointers from the more experienced users.
I have a Nice Wingokit WG400 with a Nice A400 control unit. I recently replaced the control unit with one of the same model and when setting it up, I run into a frustrating problem.
Gate set up:
  - 2 WG4000 motors for 2 gates
  - no connections for Photocells at all. The only things connected to the motherboard are the motors and all NC inputs are shorted to Common. No other accessories.
When doing the automatic search, a sequence begins, but it stops midway as described below:
– Motors open briefly, first M2 and then M1    - > runs OK
– Motor M1 closes until the closing mechanical stop is reached.   - > runs OK
– Motor M2 closes until the closing mechanical stop is reached    - > runs OK
– Motor M2 begins opening.  - > NOT OPENING
– After the programmed delay, motor M1 begins opening.   -> NOT OPENING
So the gates remain closed and never open to complete the sequence. A clicking sound from the control pannel is heard, like a switch trying to open/close, but the gates never open.
Any thoughts on what I should be checking ?
Thank you !
Found the bug! I had to connect the photocells for the automatic search to perform correctly. Testing with all NC inputs shorted to Common, did not cut it.
All is working fine now. The learning procedure completed successfully.
  nice robus D400 smartphone control YOSH 1 916 05-03-2024, 04:45 PM
  Nice MC800 Wiring issue Adamzsite 2 916 05-03-2024, 04:37 PM
  nice robus troubleshooting tarmongaidon 7 16,882 30-01-2024, 05:19 PM
Last Post: hasanova
  Nice photo sensor issue F210 and MC824H gates won’t operate Tantrum 1 1,906 04-01-2024, 10:06 AM
  Nice Robus RBA3c Wifi Relay Switch Wiring denis 1 2,377 01-11-2023, 09:45 AM
  NICE MC800 Factory Reset bg148 5 3,397 12-10-2023, 01:11 PM
  Nice MCA1 stuck open after stop command Khooke 1 2,657 25-09-2023, 10:47 AM
  Nice transmitters - compatibility Noghar 6 6,798 10-10-2022, 10:02 AM
  NICE MC82H - connecting maglock grangerd 3 4,972 10-10-2022, 09:40 AM
  Nice Robus Don't Auto Close!!!! Ali_1982 1 4,388 03-08-2022, 02:23 PM
