  • 9 Vote(s) - 2.33 Average
Older FAAC gate no power to circuit board
I have an older FAAC gate that I inherited from the prior homeowner. After just replacing all the gate sensors for about $1k and basically capping what I can afford to put into this gate, know about a week later I don't have any power to the circuit board. All the lights are off, picture included. This happened after I turned off the power to the circuit board one morning (by using the switch in the electrical box where the circuit board is) and then when I turned it back on I had power in the lines leading into the circuit board, but nothing on the circuit board and no gate functionality. Is there anything obvious I'm missing here? Wondering if there is any sort of reset that is an easy fix I can do myself? I see there are grey and black knobs in the lower left and top middle which say fuse on the end with a counterclockwise arrow - didn't know if this might be a solution. I don't see any obvious signs of the circuit board being fried and like I said at the beginning it was working fine, I killed the power to it and no it just won't work with the power on again. Any help would be greatly appreciated with this.
thanks,
Tim
  Fried control board nickfr 3 596 22-03-2024, 12:53 PM
  BFT key pad not communication with digital board niall.paul@yahoo.co.uk 1 487 14-02-2024, 12:21 PM
  Faac 452 pcb board benner91 2 1,852 09-02-2024, 06:13 PM
  Faac photocell stopped working Zeb Gulickx 2 1,108 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  TC fault code on Q60ar control board Skydive1710 3 3,623 20-11-2023, 03:12 PM
Last Post: NormanY
  FAAC E124 fault 05 allan@amtas.com.au 0 767 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  Holding the Gate Open mgb 1 3,922 11-07-2023, 01:35 PM
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 4,180 03-07-2023, 08:54 AM
  7pcb452/455 FAAC Alpin 0 1,258 23-06-2023, 03:19 PM
Last Post: Alpin
  BFT gate and Hikvision wiring help Gowrie 0 3,754 26-05-2023, 02:05 AM
Last Post: Gowrie
