  • 7 Vote(s) - 4.14 Average
Robus 600 not closing fully
#11
(20-07-2022, 09:47 AM)SamA Wrote:
(19-07-2022, 08:36 AM)All Well Wrote:
(18-07-2022, 10:38 AM)SamA Wrote:
(18-07-2022, 09:05 AM)All Well Wrote:
(18-07-2022, 08:59 AM)SamA Wrote: Hi,
Thanks. Another thing: Can minor adjustment be made to the closed position. The gate stops about an inch or so short which prevents proper locking.
Of course.
Finally found the solution: At the rear end of the close contact lever there are two screws which can be loosened and the lever moved backward or forward to make the gate stop later or earlier respectively. So it is a mechanical adjustment solution!
Thanks a lot. Regards
(10-07-2022, 09:31 AM)All Well Wrote: I have a RB600 sliding gate installed working ok past one year. Lately noticed not closing fully, about an inch shorter than the mechanical stop. Have run the 'Recognition of Gate Length' program without resolution.
Any suggestions on what next?
Thank you for bringing this to our attention,
I would recommend nothing down what the Bluebus LED is doing when the fault occurs and this will give us a good indication as to what is happening, it will either be flashing once per second to resemble everything is fine or flashing multiple times and pausing to indicated a fault, we would need to know how many times it is flashing before it pauses.
Furthermore you could always try and up the force on the panel by going and changing some of your second level functions.
  Program a 3rd party remote to Nice Robus N600 P100D 4 125 13-05-2024, 03:36 PM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 28 17,513 10-05-2024, 08:27 PM
Last Post: Nemen3242
  Nice Gates not closing StuL 1 1,743 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 9,776 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  LIFE AC4 Closing Issues dilbertdog 0 716 29-07-2023, 02:59 PM
Last Post: dilbertdog
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 4,268 02-12-2022, 02:51 PM
  Aria 400 - gates keep opening and closing objohnuk 1 4,275 13-04-2022, 11:32 AM
  Faac 455d Gates not closing, 2 led bars on display only Mkeowd 0 4,462 26-09-2020, 02:29 PM
Last Post: Mkeowd
  Faac 770 455D Gates Auto closing framsbottom 6 17,236 23-04-2020, 08:56 AM
Last Post: framsbottom
  bft giuno ultra bt a20 not closing trackham 0 3,203 21-01-2020, 11:47 AM
Last Post: trackham
