  • 8 Vote(s) - 3.5 Average
Came ZLJ24
I am wanting to connect my GSM intercom to the ZLJ24 panel, instructions given are to wire to the Com port and the No port, unable to find these in the panel, 5 wires from controller , Open Pedestrian, Common, Open, AC/+VE  and  AC/GND. Any information would be VERY much appreciated,
I hope you are well. Please see the terminal descriptions below.
Terminals 3 - N/O
Terminals 1 Com
You will need to wire from the relay output on the intercom to the N/O and COM on the ZLJ24 panel. You can see this shown in the manual which i have linked below for you. You will need to refer to page 6/32 on the PDF. Note this will be using the 'Key selector and/or opening button (N.O contact)'.
https://manuals.easygates.co.uk/PDF/misc/ZLJ24.pdf
I hope this has helped.
Kind regards
- Jamie
  CAME ZLJ24 Control Panel SmtsFnd 5 1,240 08-05-2024, 08:57 AM
  ZLJ24 Reversed Paulgates 1 683 15-04-2024, 12:05 PM
  Help with intercom to Came ZLJ24 paulaj 0 5,055 15-06-2020, 06:27 PM
Last Post: paulaj
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 16,553 02-05-2018, 06:18 PM
