  • 114 Vote(s) - 2.64 Average
CAME ZLJ24 panel - Open gate indicator-light
    Greetings friends!
Forgive me if I am posting in the wrong place..!!! I'm new here!
I would like more information about this 'open indicator-light'. I checked the installation/programming manual and can only find reference to it as being connected to 11 and 5 on the terminal rail.
I tested the voltage at 11 and 5 throughout a few open/close operations but failed to detect any voltage accross 5 and 11 at any stage. I was expecting to pick up 24vac when the gate/s begin to open or are completely open. I have read the programming section but only see reference to the cycle lamp / flasher lamp on 10-E
Is the Open gate indicator-light a bit of kit supplied by CAME??
What is its role in the operation of the gate.
regards
Dom
did you check dip-switch position ?
i got manual frome came zl160 and indicator light output is between 5 and 10 (24v 3W max)
regards
  CAME ZLJ24 Control Panel SmtsFnd 4 648 25-04-2024, 08:38 AM
Last Post: SmtsFnd
  ZLJ24 Reversed Paulgates 1 358 15-04-2024, 12:05 PM
  CAME sliding gate drops codes after power outage Catch 1 2,191 02-03-2023, 03:18 PM
  My Came ZM3E gates won’t open golfnut75 1 5,133 12-08-2022, 08:40 AM
  CAME ZA3 Not opening & red light (program) flashing RandC 7 96,287 09-01-2022, 11:48 AM
Last Post: dj_singh
  Came FROG - one leaf occasionally does not open fezster 3 7,560 03-08-2021, 10:07 AM
  Came ZLJ24 Lyneve 1 3,539 16-07-2021, 12:35 PM
  Help with intercom to Came ZLJ24 paulaj 0 5,032 15-06-2020, 06:27 PM
Last Post: paulaj
  Link Came F7000 gate openers to Enterview 3 Intercom Jackolantern 2 10,243 23-04-2020, 07:11 PM
Last Post: Luke Scott
  Came ZA3 Control panel - Green LED Flashing BarryD 0 11,864 18-07-2016, 11:19 AM
Last Post: BarryD
