  • 12 Vote(s) - 2.58 Average
Nice remote fob
Can you reprogram a nice remote fob that has been used on a different gate? Tried pairing and doesn’t work! Think it needs wiping. Any ideas?
I have a nice robus 600 and couldn't find my remotes. Is it possible to buy new remotes online and program them without using the old ones.
Pls help
Quote:Hi
Can you reprogram a nice remote fob that has been used on a different gate? Tried pairing and doesn’t work! Think it needs new updates on this post regarding phenq wiping. Any ideas?
SAME QUESTION Sad
(24-08-2020, 08:28 AM)Deb Wrote: Hi
Hi Deb,
You are able to program other NICE remotes which have been programmed to another gate. This being said it must match the type of remote you already have. NICE manufacture multiple remotes and all of them may not be compatible with your system, or cannot be programmed at the same time as other types of remotes.
Do you have any information on the existing remotes or remote you are trying to program?
(12-09-2020, 07:27 PM)Farid Wrote: I have a nice robus 600 and couldn't find my remotes. Is it possible to buy new remotes online and program them without using the old ones.
Pls help
Hi Farid,
You can purchase new remotes from EasyGates Ltd. To program the remotes you would need to access the receiver inside the motor housing and follow the programming procedure for your receiver. The ROBUS will usually have the NICE OXI receiver inside. You can find the programming information on manuals.easygates.co.uk by searching robus 600
  nice robus D400 smartphone control YOSH 1 900 05-03-2024, 04:45 PM
  Nice MC800 Wiring issue Adamzsite 2 902 05-03-2024, 04:37 PM
  nice robus troubleshooting tarmongaidon 7 16,836 30-01-2024, 05:19 PM
Last Post: hasanova
  Nice photo sensor issue F210 and MC824H gates won’t operate Tantrum 1 1,890 04-01-2024, 10:06 AM
  Nice Robus RBA3c Wifi Relay Switch Wiring denis 1 2,364 01-11-2023, 09:45 AM
  NICE MC800 Factory Reset bg148 5 3,377 12-10-2023, 01:11 PM
  Nice MCA1 stuck open after stop command Khooke 1 2,642 25-09-2023, 10:47 AM
  Nice transmitters - compatibility Noghar 6 6,783 10-10-2022, 10:02 AM
  NICE MC82H - connecting maglock grangerd 3 4,964 10-10-2022, 09:40 AM
  Nice Robus Don't Auto Close!!!! Ali_1982 1 4,385 03-08-2022, 02:23 PM
