  • 3 Vote(s) - 2.67 Average
Hold electric gates closed
I have a customer with a question I can't find an answer to...maybe you guys can help? Their double gates are driven by two BFT actuators controlled by a Rigel 4 controller. Photocells are located across the drive on the inside (house side) and their toddler has just discovered he can open the gates by running through the beam! Is there a way of temporarily disabling the photocell beam so the gates do not open? I have studied the controller instruction manual but can't find such an option........Any suggestions apart from locking the gates together or switching off the power to the controller?
Sorry......It is a Rigel 5 controller, not Rigel 4 as stated in post above.
Are the photocells used as an open input and not a safety input? If they are used to allow free exit the only way to disable this would be to disconnect one side of the relay in the photocell. An option for you customer would be to have an induction loop fitted so the gate would only open when a vehicle drove over it.
  Rigel 5 , gates won't open Nameloc 4 3,894 04-05-2024, 12:41 PM
Last Post: Alee
  Gates tripped Phil.c 3 325 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 412 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 1,733 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 9,020 07-01-2024, 07:11 PM
Last Post: Simon NW
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 1,930 02-10-2023, 09:20 AM
  Nice Gates not closing StuL 1 1,663 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 9,723 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Came gates stuck open. Ring8180 7 17,173 23-02-2023, 01:08 PM
  Electric gate help PLEASE Be8st 5 6,233 18-10-2022, 09:26 AM
