  • 9 Vote(s) - 2.78 Average
BFT Rigel 5
Hi there,
We have just replaced the posts that were housing one pair of photocell sensors to our gates. That meant disconnecting and rewiring the photocelles. Everything has been replaced as it was however on inspection there is now no power to the control unit at all. All fuses seem to be ok.
I wonder if anybody has any ideas? There is nothing showing in the LCD.
Thanks much!
You will need to check the board is still receiving its mains feed in by using a multimeter, or checking the supply RCD hasn't tripped. If all of this checks okay you may need to check the board does not have any damage on it from insects on the back of the PCB by removing it from its enclosure and looking at it.
  Just Got A Rigel 5 and need HELP!!!! rapley 2 13,388 04-05-2024, 12:47 PM
Last Post: Alee
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,383 04-01-2024, 10:21 AM
  Rigel 6 conections Muttlymoo1979 0 1,479 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Er 10 code on RIGEL 6 control unit Eddiew 1 2,881 05-01-2023, 11:53 AM
  BFT Rigel 6 - Buttons suddenly stop working RobE 5 5,036 10-10-2022, 01:10 PM
  Rigel 6 - doors do not stay open Poweroftaxi 1 9,422 13-04-2021, 02:41 PM
  But Rigel 5 and Deane a15 cells Matt Hey 2 9,056 30-03-2021, 07:57 AM
Last Post: Matt Hey
  Bft rigel 6 PHCL tidoh2021 1 11,891 12-03-2021, 07:31 PM
Last Post: russ
Smile Rigel 5 Manual override Stramorebees 0 10,150 20-09-2020, 12:03 PM
Last Post: Stramorebees
  BFT Rigel 5 Issue kw1 0 9,678 16-08-2020, 02:04 PM
Last Post: kw1
