  • 10 Vote(s) - 2.9 Average
Broken bft gates
Hi all,
I am new to this site, so please be kind
This morning my bft swing gates opened fine, but now they will not move!
I have read other posts and the display in the main box says phot
When I press the open button the display changes from phot to strt then straight back to phot
I have cleaned the 4 sensors inside and out and am at a loss
Any ideas would be greatly appreciated
Chris
i would recommend removing all cells and running short leads from the cells directly to the panel.
this most likely will be a short on the cable causing the cells to go open circuit.
if not possible please bell out the cables for a continuity check.
“Phot”is a fault on safety circuit. I’d check each set of beams, one side of each set of beam should be clicking as you cover/uncover. If neither on 1 set are clicking you likely have some faulty beams. Check phot PCBs for corrosion/insects.. they may have blown your accessories fuse. Do you have any lights on any of them?
  Rigel 5 , gates won't open Nameloc 2 3,784 23-04-2024, 08:35 AM
  Gates tripped Phil.c 2 227 22-04-2024, 11:27 AM
  Came ZA3 gates stuck open Ivorwindybottom 0 384 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 1,636 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 8,975 07-01-2024, 07:11 PM
Last Post: Simon NW
  Nice Gates not closing StuL 1 1,591 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 9,662 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Came gates stuck open. Ring8180 7 17,069 23-02-2023, 01:08 PM
  Aria 400 - gates keep opening and closing objohnuk 1 4,212 13-04-2022, 11:32 AM
  Gate Controls/Indicators 200m from Gates ADickson 12 57,171 30-12-2021, 11:44 AM
Last Post: herberthaul
