  • 5 Vote(s) - 2.6 Average
Daitem intercom not working
I have a Diatem intercom keypad with single call button, coupled to a NICE gate opener, the keypad starting flashing repeatedly and then stopped working.
the internal intercom will open the gates, and the nice fobs will also open the gates, but the key pad didnt do anything at all.
I changed the battery in the external controller and this allows the keypad to open the gate and call the internal handset - but it wont beep or light up?
any ideas.... ?
Thank you in adavance
I’ve had exactly the same issue, the problem I had was that the keypad was wet after heavy rain. I had to take mine apart (carefully!) and dry it with a hairdryer.
I then left it in a warm place to dry out thoroughly for about 6 hours.
I put it back together and it now works perfectly!
  GSM intercom DBElectric 1 2,331 17-06-2022, 12:30 PM
  Daitem gate control novice help needed... TimRW 0 4,945 29-03-2021, 07:58 PM
Last Post: TimRW
  Daitem SC900AX Not Working - Help Please! Eskimo 0 25,377 09-04-2018, 08:04 PM
Last Post: Eskimo
  AES DECT GSM Intercom landline dial programming manchester_sparks 0 16,645 18-03-2018, 09:02 PM
Last Post: manchester_sparks
  Handset system DAITEM D5131GB Carlo 1 28,664 18-01-2017, 10:49 AM
  Daitem D5300 is it compatiable with SC902AU steve redwood 2 24,646 02-01-2015, 02:55 PM
  Daitem D5731gb system royaugout 1 24,392 02-01-2014, 04:15 PM
  Daitem wireless intercom Mel1962 0 20,781 25-07-2013, 12:49 AM
Last Post: Mel1962
  Daitem CTS5200 Controller babypomdiy 1 21,795 16-05-2013, 10:16 AM
Last Post: Blakey111
Shy Farfisa Intercom - Version PT 5160W Carolyn1Dickson 1 18,495 10-04-2013, 02:17 PM
