  • 199 Vote(s) - 3.01 Average
Handset system DAITEM D5131GB
I had trouble exactly same about 18 months ago.
Again I have lost signal to open gates or use intercom
I have fitted new batteries. When I press the little button in the controller and within 20 secs press the external intercom button it beeps as supposed to. Then within 20 secs I press the two buttons on the handset as shown in the handbook
But it does not beep as to show connected.
The small Came remotes work perfect. But not the phone handsets
Any advice please
Thank you
Hi Carlo,
Can you explain what issue you have with the Daitem handset? Does it have speech? Can you open the gate with it? if cannot do both of the above, then i would say that the handset is faulty. You will need to replace the entire daitem system for the new update digital version as they are not compatible with each other.
http://www.easygates.co.uk/wireless-intercoms.asp
(07-01-2017, 08:47 PM)Carlo Wrote: I had trouble exactly same about 18 months ago.
Any advice please
Thank you
  Comelit audio handset no longer opening gates US1549 1 5,202 14-03-2023, 10:25 AM
  Daitem gate control novice help needed... TimRW 0 4,937 29-03-2021, 07:58 PM
Last Post: TimRW
  Daitem intercom not working mikecymru 1 16,054 19-12-2020, 08:56 PM
Last Post: Andy
  Daitem SC900AX Not Working - Help Please! Eskimo 0 25,364 09-04-2018, 08:04 PM
Last Post: Eskimo
  Daitem D5300 is it compatiable with SC902AU steve redwood 2 24,628 02-01-2015, 02:55 PM
  Daitem D5731gb system royaugout 1 24,375 02-01-2014, 04:15 PM
  Daitem wireless intercom Mel1962 0 20,770 25-07-2013, 12:49 AM
Last Post: Mel1962
  Daitem CTS5200 Controller babypomdiy 1 21,771 16-05-2013, 10:16 AM
Last Post: Blakey111
  Daitem d5731gb wireless intercom - Instructions needed Poppet 1 36,892 19-12-2011, 11:33 AM
  New daitem / logisty wireless intercom systems KIT SC902AU BarkerandGeary 3 31,232 18-10-2011, 09:31 PM
Last Post: alban gates
