  • 250 Vote(s) - 2.95 Average
BFT Deimos Ultra remote problems
Hi Guys,
I have a BFT Deimos Ultra 600 and I'm have a problem adding new remotes. I can add new remotes and that seems to partially work. However the new remotes can't seem to open the gate.
What happens is: I press the button on the remote and nothing happens if the gate is closed. If it is open, it will close. If I use an existing remote, it opens right up and I can use a new remote to control the gate.
I notice that the display shows nothing when I use the new remote, but it displays something when I use the old one to open the gate. It's almost like the new remote is missing something to 'wake up' the unit on opening.
Any ideas on what is happening here?
How did you add the remotes into the Deimos, through the control panel on the motor or by cloning an existing remote. Maybe try doing opposite method of adding your remotes, I.E if you added them by cloning try adding by the control panel or vice versa
  Question BFT Deimos A400 Makaroni 0 137 15-05-2024, 08:05 AM
Last Post: Makaroni
  BFT Deimos BT A600 fault Error 10 Airbus330/300 5 6,982 06-03-2024, 11:59 AM
Last Post: GateOpe
  BFT deimos smoke from board stanli200188 1 1,181 05-03-2024, 04:17 PM
  Set remote to “only open” gate mark123499 4 4,161 30-05-2023, 01:57 PM
Last Post: mark123499
  Remote only working close up Uphill 0 2,709 03-10-2021, 07:50 PM
Last Post: Uphill
  bft giuno ultra bt a20 not closing trackham 0 3,867 21-01-2020, 09:28 PM
Last Post: trackham
  BFT Deimos Ultra BT A 600 + Tbox ok.dude 1 6,823 30-04-2019, 09:32 AM
Last Post: ok.dude
  BFT Deimos - How to fit a GSM Switch. MyGatesDontWorkSoGood 0 6,267 02-06-2018, 04:46 PM
  BFT Deimos A600 (HAMAL control board) troubleshooting EnricoTerni63 1 14,854 23-12-2017, 05:38 AM
Last Post: TAOZ
  BFT Deimos gate won't close Arthur_k99 15 78,800 03-07-2017, 02:58 PM
Last Post: Arthur_k99
