  • 103 Vote(s) - 3.27 Average
BFT Deimos - How to fit a GSM Switch.
Hello Everyone.
We recently bought a house which has a BFT Deimos sliding gate unit. When opened, the gate slides into a recessed area that is covered over (the drive is on a slope, and the gate goes into a glorified culvert basically...).This was connected to a Videx Intercom and Access unit, an as yet unidentified and disconnected receiver and a Hormann receiver. The Hormann would have been fitted as the garage door is also operated by a Hormann unit, so presumably the previous owner wanted to use the same remote.
Unfortunately at some point the Deimos unit was unbolted and left aside minus the cover, the Videx transformer left to the elements, and both remote receivers uncovered and dangling from a spaghetti explosion of cables.
After removal, cleaning and tinkering, the Deimos unit seems to be fully working, but minus the original remotes. The Videx side of things also seems to be working too, but I am inclined to install a GSM unit to open and close the door, as we have a lot of visitors and family.
I was thinking of something like this, which I'd imagine is familiar to some folks:-
[Image: 61qe2cDdX8L._SY450_.jpg]
I'm aware this is a budget item and are only using it as a general example, but my issue is that this (and most of the others I've looked at) seem to have only one relay output, whereas the Deimos unit appears to need two signals from relays, one to open and one to close. So, am I being a numpty and missing something or do I need one that has two relays.
Looking forward to hearing some replies and thanks in advance.
  BFT Deimos BT A600 fault Error 10 Airbus330/300 5 6,560 06-03-2024, 11:59 AM
Last Post: GateOpe
  BFT deimos smoke from board stanli200188 1 911 05-03-2024, 04:17 PM
  BFT Deimos Ultra remote problems shaggy 1 11,219 01-05-2019, 09:43 PM
Last Post: ok.dude
  BFT Deimos Ultra BT A 600 + Tbox ok.dude 1 6,603 30-04-2019, 09:32 AM
Last Post: ok.dude
  BFT Deimos A600 (HAMAL control board) troubleshooting EnricoTerni63 1 14,686 23-12-2017, 05:38 AM
Last Post: TAOZ
  BFT Deimos gate won't close Arthur_k99 15 78,382 03-07-2017, 02:58 PM
Last Post: Arthur_k99
  Installation Problem - BFT Deimos BT + GSC D MA boblalux 4 88,068 27-12-2015, 10:08 PM
Last Post: boblalux
  Limit Switch for BFT P7 arm with Rigel 5 Control Securus 0 6,944 16-05-2014, 09:37 PM
Last Post: Control Securus
  DEIMOS BT Issue - Advice please rawstrona 1 11,456 09-01-2009, 03:39 PM
