  • 7 Vote(s) - 2.29 Average
BFT Deimos Ultra BT A 600 + Tbox
I have the following Gate Motor BFT Deimos Ultra BT A 600, It's all installed and working. I have a few programming questions if any one can help it will be greatly appreciated.
The a pair of Thea A15 O.PF Photosells, I'm sure they are wired correctly but they don't appear to function. Do I need to turn them on and if so how.
I have a 2 button remote and the 2nd button is programmed to Channel 2. I want to set channel 2 to operate Pedestrian opening mode. When I press the 2nd button it appears to work as I can hear a relay click when its pressed, but it doesn't operate the gate. how do I turn this feature on.
Tbox is also programmed to channel 2 as well. this makes the relay click when the correct code is entered so it must be a case of programming.
In case it helps I have not removed any of the jumper wires that are preinstalled from the factory in JP8 70-75
Does the TBox have rolling codes ?
Sorry for all the questions I've tried to following the programming diagram in the manual but it's confusing Sad
Thanks in advance
Just an update tommy original post I have managed to sort the Thea A15 O.PF Photosell problem.  It was a wiring problem, D'oh
I still need help with:-
I have a 2 button remote and the 2nd button is programmed to Channel 2. I want to set channel 2 to operate Pedestrian opening mode. When I press the 2nd button it appears to work as I can hear a relay click when its pressed, but it doesn't operate the gate. How do I turn this feature on.
  BFT Deimos BT A600 fault Error 10 Airbus330/300 5 6,795 06-03-2024, 11:59 AM
Last Post: GateOpe
  BFT deimos smoke from board stanli200188 1 1,056 05-03-2024, 04:17 PM
  bft giuno ultra bt a20 not closing trackham 0 3,851 21-01-2020, 09:28 PM
Last Post: trackham
  BFT Deimos Ultra remote problems shaggy 1 11,343 01-05-2019, 09:43 PM
Last Post: ok.dude
  BFT Deimos - How to fit a GSM Switch. MyGatesDontWorkSoGood 0 6,185 02-06-2018, 04:46 PM
  BFT Deimos A600 (HAMAL control board) troubleshooting EnricoTerni63 1 14,765 23-12-2017, 05:38 AM
Last Post: TAOZ
  BFT Deimos gate won't close Arthur_k99 15 78,643 03-07-2017, 02:58 PM
Last Post: Arthur_k99
  Installation Problem - BFT Deimos BT + GSC D MA boblalux 4 88,163 27-12-2015, 10:08 PM
Last Post: boblalux
  DEIMOS BT Issue - Advice please rawstrona 1 11,490 09-01-2009, 03:39 PM
