  • 151 Vote(s) - 3.2 Average
Q60A/R error. Showing "_ "
Hi there,
I found water inside the my proteco automation central case.
One fuse have blown. I've changed it but now show me the following error:
On stand by it only shows "_ ", and when cycling throuh the button A (the only button that does anything) it is showing
the following.
Q60 error video
Ty in advance for an help!
(02-11-2017, 08:25 PM)Jonas Pistolas Wrote: Hi there,
the following.
Q60 error video
You should at the begining take the central to the house and dry it .
which fuse blow up ? high voltage or low
The 5A fuse was the one that had blow up.
I already dried everything very well, but with no sucess.. ?
(03-11-2017, 05:13 AM)Jonas Pistolas Wrote: The 5A fuse was the one that had blow up.
http://manuals.easygates.co.uk/PDF/misc/mygate.pdf
you should check all accessories photo,receiver etc ...... with manual you can try to programing once again ..
Thank you for the manual.. i already got it, and none of the central error messages are described on the manual. I'm not able to do any programming, as a reset.
I already disconnected everything, and nothing changes...
I was wondering if there is a way to force the central to a reset...
Bests,
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 17,999 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 974 19-06-2023, 01:03 PM
Last Post: xCO
  Replacement Q60A board? ndyhzlwd 1 1,921 10-02-2023, 03:19 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 3,143 12-07-2022, 11:48 AM
  Proteco Q60 - FH error then close after opening Needlerp 1 2,387 24-06-2022, 09:54 AM
  proteco q60a microcontroller program arashkhan 1 2,599 17-06-2022, 01:29 PM
  Thalia P - BAR error devsolo 2 9,529 07-01-2021, 04:05 PM
Last Post: GilbertoMoncada
  Deimos BT 400/600 error codes orange 0 3,910 07-12-2020, 09:36 AM
Last Post: orange
  Fav sliding gate error code plus other Adam67 0 9,022 02-09-2020, 07:06 PM
Last Post: Adam67
  Re: Error 30 tony.jay8 2 11,105 10-05-2018, 11:17 PM
Last Post: tony.jay8
