01-08-2018, 07:41 PM
Hi. New here. I have just installed my new gates The program is flashing on pcb board I have fitted radio frequency board but I don’t have any photo cells how do I short out them ? Thanks in advance
Came gates za3p
03-08-2018, 08:42 PM
2-1 / 2-c1/ 2-cx / there are three NC contact bridge them up Best Regards
03-01-2024, 12:39 PM
ZA3P Blew with a slug dancing across the board. Replaced with a brand new one and worked for 2 days then was tripping RCD in house. Removed board, no slug / insect, checked all wiring but keeps tripping RCD. Board has a Remootio 3 attached for wifi gate opening and lights that come on for 10 mins after gate activation. 2 arm gates ATS30 - any ideas?
Tested capacitors in arms, only thing I can think of is limit switch in arms was knackered by gate installer ~ 1 year ago - could the fault be with the arm?
04-01-2024, 10:12 AM
Hi Simon
I would suggest disconnecting all accessories from the board and run 1 motor at a time. This would determine whether it is a motor issue or a control board issue as i doubt both motors would cause the RCD to trip. Regards Easygates 1
EasyGates.co.uk - EasyGates Ltd
EasyGates Direct - Trade only accounts. Smart and Secure Center - Smart Home Products
07-01-2024, 07:11 PM
(04-01-2024, 10:12 AM)Michael Wrote: Hi Simon It was the courtesy light(s) - new bulbs purchased, reconnected, blew again so no lights. Different issue - limit switches are off on the board, but now left hand gate will open, but not close. I am guessing the Limit switch in the ATS30 is knackered (like the right hand gate is)? |
« Next Oldest | Next Newest »
Possibly Related Threads… | |||||
Thread | Author | Replies | Views | Last Post | |
Rigel 5 , gates won't open | Nameloc | 4 | 3,980 |
04-05-2024, 12:41 PM Last Post: Alee |
Gates tripped | Phil.c | 3 | 407 |
01-05-2024, 09:34 AM Last Post: Phil.c |
Came ZA3 gates stuck open | Ivorwindybottom | 0 | 454 |
18-02-2024, 06:29 PM Last Post: Ivorwindybottom |
Electric Gates with AllMatic BIOS2 Unit | antsnaith | 3 | 1,859 |
31-01-2024, 08:22 AM Last Post: patronsecurity |
Nice Gates not closing | StuL | 1 | 1,743 |
24-08-2023, 01:34 PM Last Post: JoeF |
Gates Opening After Closing | tht7 | 2 | 9,775 |
30-07-2023, 12:30 PM Last Post: lcpbarbosa |
Came gates stuck open. | Ring8180 | 7 | 17,252 |
23-02-2023, 01:08 PM Last Post: SamA |
Aria 400 - gates keep opening and closing | objohnuk | 1 | 4,275 |
13-04-2022, 11:32 AM Last Post: JoeF |
Gate Controls/Indicators 200m from Gates | ADickson | 12 | 57,283 |
30-12-2021, 11:44 AM Last Post: herberthaul |
Proteco gates with photocell problem. | Shane1 | 0 | 2,210 |
09-10-2021, 07:56 PM Last Post: Shane1 |
