  • 200 Vote(s) - 2.6 Average
Slider closing then reopens 8"
BFT Icaro Prox MA-D Motor, BFT ALTAIR P Panel
When the gate closes it reopens by 6" - 8"
Any ideas?
MWJGATES
www.mwjgates.co.uk
info@mwjgates.co.uk
01327301796
(06-12-2015, 08:37 PM)MWJONES Wrote: BFT Icaro Prox MA-D Motor, BFT ALTAIR P Panel
Any ideas?
There are several reasons why this can happen.
If safety edges are fitted, the edge may be hitting the closing post, if you have an edge and you have tco4 fitted battery may be almost dead, or your edge may be damaged.
If the gate has slowdown on it and it say starts its slow down at say 2 foot away from being fully closed, there may be damage to bearings, track, drive rack or if it runs on a rail there may be damage there,
try increasing the close torque first, check above, if it still fails and there is a rundown distance set , decrease the distance to half and see if that works.
Many thanks. No issue with safety edges or batteries. Will try increasing the torque
MWJGATES
www.mwjgates.co.uk
info@mwjgates.co.uk
01327301796
Bft gate opener acting Crazy. It opens and 2 second later starts closing on it own. It mostly happens early in the morning or late at night. It got much worst after technicians serviced with changing the oil.
Any ideas?
thanks for the email,
this issue here sounds to be either an issue with the location of the limit switches for the motor and or a force reversal of the motor, i would guess that it would be the latter. have you tried to relearn the limits on the motor or increase the force on the motor?
Kind Regards,
  BFT Sliding Gate randomly opening and closing AdrianMate 2 1,274 17-05-2024, 10:30 AM
Last Post: Adamit
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,415 04-01-2024, 10:21 AM
Exclamation BfT Sub R - No Closing pressure 1 Leaf Bushpig 2 3,309 23-05-2023, 03:48 AM
Last Post: Bushpig
  BFT SubR not opening/closing sometimes Jimmyboy4 3 3,111 09-01-2023, 10:29 AM
  Gates not fully closing stefen1978@hotmail.co.uk 2 2,854 10-10-2022, 10:07 AM
  LUX G BT 2B not closing properly since manual override swinnie 1 2,150 03-08-2022, 01:44 PM
  BFT Lux 2B FC Motor not closing all the way jc.34@outlook.com 1 3,210 07-03-2022, 11:24 AM
  Phobos reversing after closing Sim75 0 2,367 21-05-2021, 07:04 AM
Last Post: Sim75
  Gates not closing (BFT Thalia btl2 and Bft Desme) Joel23M 2 7,863 17-01-2021, 01:25 PM
Last Post: Joel23M
  BFT Gate Opener not closing Anay 2 86,539 17-02-2020, 02:19 PM
Last Post: Caesium
