  • 440 Vote(s) - 2.82 Average
Rigel 5... cell question
Hello all
Newbie here, trying to sort out my gates after the electrican messed them up!
Got the motors, capacitors and keyfobs sorted out.
I have a 'push to open button'. That is N/O across 30 and 31
My question is the photocells. Power is 20/21 for Rx and 20/44 for Tx (although I am sure they don't need separate supply connections)
I have a pair to trigger opening as you enter and another pair to trigger opening as you leave. Where do these connect?
I notice in the programming menu that they default stop and re-open if you break the beam while they are closing, which is what I need.
I also have a set directly across the gate line to prevent closure onto a car between the gates. Would these be wired N/C across 35 and 36?
If yes, then will they stop and reverse the gates or just hold them ?
Many thanks !
Steve
REF CELLS for free exit - WIRE TRIGGER RELAYS ( test em in the powered state ) to 30 & 31 volt free, this will always open the gates.
Safety cells on relay is 35&36
easier to power 20&21 for all cells
  BFT Rigel 5 issue Adamit 0 75 17-05-2024, 10:28 AM
Last Post: Adamit
  Question BFT Deimos A400 Makaroni 0 134 15-05-2024, 08:05 AM
Last Post: Makaroni
  Just Got A Rigel 5 and need HELP!!!! rapley 2 13,453 04-05-2024, 12:47 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,427 04-01-2024, 10:21 AM
  Rigel 6 conections Muttlymoo1979 0 1,519 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Er 10 code on RIGEL 6 control unit Eddiew 1 2,949 05-01-2023, 11:53 AM
  BFT Rigel 6 - Buttons suddenly stop working RobE 5 5,144 10-10-2022, 01:10 PM
  Rigel 6 - doors do not stay open Poweroftaxi 1 9,471 13-04-2021, 02:41 PM
  But Rigel 5 and Deane a15 cells Matt Hey 2 9,105 30-03-2021, 07:57 AM
Last Post: Matt Hey
  Bft rigel 6 PHCL tidoh2021 1 11,929 12-03-2021, 07:31 PM
Last Post: russ
