  • 399 Vote(s) - 2.86 Average
bft lux2b
I've refilled my hydraulic ram with idrolux oil after a repair. But now when my actuator isn't used for some time there is no movement. The motor is running. If I turn the force adjustement screws a bit then the actuator moves again, but after a while it doesn't move anymore.
Is there something I've forgotten?
Problem is solved, the vent hole was blocked by something.
Problem returns.
Now I know the bleed hole isn't blocked because oil comes out. But when the actuator isn't used for about an hour it doesn't move.
Any ideas?
  BFT LUX2B Intermittent failure to open brookkr 4 8,096 07-09-2023, 08:32 AM
